Re: the h is jumping
Posted by Janicholson on January 03, 2009 at 13:04:56 from (68.112.156.69):
In Reply to: the h is jumping posted by tn terry t on January 03, 2009 at 12:45:28:
If the shifter only allows the gear to slide a tiny bit into engagement, the fork might help push it farther into gear. (requires removal of top) Through the belt drive opening, try to move the sliding gear forward with a small pry bar. If noticible travel is there, it can be made better by brazing a layer of material onto that side of the fork, and fitting it to the slider groove. Needs .002 clearance. JimN
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
