Posted by Mark Peters on January 02, 2009 at 14:20:00 from (66.222.6.57):
In Reply to: 300U power steering posted by markkk on January 02, 2009 at 12:09:51:
markk, I`ll try to help you the best I can.I have a 300U with power steering, but mine had it on when I got it(have worked on most of the PS though).I`ll tell you how mine is.First off, it sound like you have a parts book.If thats the case,great,go to page 370.Otherwise,CaseIH has parts list online at caseih.com/parts. It makes a difference how many valves you have on your 300.I will list by item number what you`ll need.Some parts you will need with any amount of valves,others only with certain # of valves (kind of gets a little complicated !). You for sure need (1 ea.) items 2,6 & 13 (screws in where item 14 plug is)If you only have the valve for the hitch then you use (1)item 22 elbow, if you have 2 or 3 valves,you need (1) item 23 then.To answer your question on drilling your existing plates,no, theres not enough "meat" there to get enough threads in it.With that in mind,you`ll need (1) item 16 (part # 364878R1,cover w/hole in it)for single valve set up or need (2) item 16 if you have a 2 or 3 valve setup.For a 2 or 3 valve you need (1) item 22.For 2 valves, you need (1)tube, item 18. For 3 valves you need (1) item 19. Finally, you will need (1)block off plug item 21 and (1) o-ring for block off plug, item 20. The book has a couple different sizes of plug.Common size was 1/2", but check your opening. Looks like items 6,13,20,21,22 & possibly 23 are still available at CaseIH.Items 2,16,18 and 19 are for sure available at The Parts Depot.Your CaseIH dealer has to order from the Depot,you can`t order direct. I`ve probably got you mighty confused by now, but post again if you have questions. Good luck. P.S. If you have any decent salvage yerds close by, check them out first. Parts from CaseIH and The Depot aren`t the cheapest!
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
