Posted by A J on December 30, 2008 at 15:24:22 from (71.74.115.57):
In Reply to: Farmall H backfiring posted by Gregg Anderson on December 30, 2008 at 13:52:06:
If you feel comfortable that you have ruled out all things electrical & ensured that it is timed correctly, check the following: Distributor gear, Compression check of each cylinder, then with the motor running - remove valve covers - ensure proper functioning of valve springs & push rods. You might find the problem here in the top end of the motor - and need an overhaul............
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
