Posted by El Toro on December 21, 2008 at 17:20:33 from (205.188.116.73):
In Reply to: Farmall M won't run posted by George in Nebr on December 21, 2008 at 16:10:29:
There should be a screen behind the tube fitting where your gas line connects to the carburetor. It may be plugged with crud. Open that main adjusting screw near the bottom of the carburetor. Hold your hand over the throat of the carburetor while someone makes an attempt to start the engine. You should be able to keep the engine running if there's good suction and there's no fuel blockage. Hal
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
