The points and condenser are under the flat plate there after you take the cap off. Just loosen the screw for the points then remove the other screw the points will come right out becareful not to drop the screws and the same for the condenser the bolt will have to be loosened then slip out the wire and replace all in reverse of the removal with the points on the top of the cam lobe in distributor set at twenty thousandths will be fine snap plate and cap back on with rotor cap and start it up. It is not needed to remove the plug wires. For more info get an ITT book from TSC or this site here for the tractor your working on will give point gap and all specs for tractor. Good luck
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
