Posted by mkirsch on December 20, 2008 at 13:41:03 from (67.240.251.254):
In Reply to: M stuck in 3rd gear posted by minnesota red on December 20, 2008 at 13:27:24:
What do you mean by stuck?
Will the tractor move?
Will the shift lever move?
It's very common for these old tractors to get stuck in two gears at once. The main symptom of this is that the tractor won't move when you let out the clutch no matter what gear you put it in. Sometimes the gears will jam and you can't shift it either.
The cause of this is the nub on the end of the shift lever gets worn and slips out of the shift forks. To get it unstuck, you need to remove the lever and manually pry the shift forks back to neutral. To fix it permanently, you need to build up the end of the shift lever with weld and reshape it back to its "new" form.
If the tractor is in 3rd, will move in 3rd, but you can't move the shift lever, you may have major problems inside the transmission. You may have to remove the transmission cover and figure out what is wrong.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
