Harvey: You have a Cub LoBoy and the serial number is 21969 the number you found on the steering box. Metal tag on steering box is the location of Cub serial numbers. I suspect Cub and Cub LoBoy share the same sequence of serial numbers. J stands for rockford clutch. All those numbers you see ending in Rxx are part numbers.
The engine will have a serial number, however I'm not familiar where it is on a Cub. You have to remember that Cub engine is quite unrelated to other IH engines. Most other IH engines have the engine serial number directly below number 1 plug on right side and that number is stamped on a machined flat surface. It is stamped, as opposed to cast letters or a tag.
Most other IH engines being overhead valve, places the plugs on the side, however Cub plugs are on top. Look for the machined flat surface anywhere on the block.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
