Bigr: To get rid of calcium, get a barrel, 3 are better. lay tire and rim on top of barrels with valve stem down, pointing into one of the barrels. Let it drain into a barrel, as it drains out put a 6" block under tire, opposite side from valve stem. Walk away and forget it for 3 days, it will drain out. If you have a way to add air, you can speed up the draining.
Put the barrels of calcium in a back shed. great for dust control in summer or ice control in winter. Don't worry about harming vegitation, it takes a lot of calcium that strength to do any damage. I lost the entire contents from a 20.8x38 in one spot, middle of a corn field. Two weeks after corn was up, one couldn't find the spot. At harvest time it couldn't be seen. The next year I seeded the field to alfalfa, still couldn't see the spot. That 20.8x38 probably had 5 times the calcium chloride you 11.2x36 will.
Once you have the calcium out, follow the direction given by Gene.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
