Sure it will, if its converted to a 12 volt genny it will charge a 12 volt battery, thats the whole idea. Actually, while I'm NOT recommending this (its NOT engineering correct) I've used 6 volt gennys as is no conversion and just changed to a 12 volt Voltage Regulator and they worked okay (it can overcurrent the field windings ya know). A shop can convert it from 6 to 12 volts and will change out the Field windings and do it right, however. Or just buy a used or rebuilt already 12 volt genny.
Of course, you also need a 12 volt Voltage Regulator if you stay with a generator and use a 12 volt generator,,,,,,,,,,,, Change any lights to 12 volts,,,,,,,,,,,,EITHER use a new full true 12 volt coil (NO ballast required) or else if you use a 6 volt coil add an external voltage dropping (12 to 6) series ballast resistor after the ignition switch but before and ahead of the coil.
If you wanna change polarity the ammeter leads need swapped or it will read bass ackwards,,,,,a coil should match the battery polarity, i.e. at Pos ground its lil - terminal gets ignition switched voltage input while its other lil + wires to distributor but at neg ground thats reversed.
Dont forget to POLARIZE the genny BEFORE you start the tractor !!!!!!!!!!!!!!!!!!!!!!!!
If you go with an alternator instead most all require Negative ground.....
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
