Posted by Bill Hires on December 09, 2008 at 04:58:07 from (128.206.120.184):
In Reply to: Gas tank dent on 130 posted by EZ on December 08, 2008 at 20:06:20:
I use a pipe plug the size of the sediment bowl fitting with a hole drilled in it so a tire tube valve stem with the rubber removed will fit. I JB weld the stem into this hole and after it cures put the tank cap on and apply air pressure. I have never had to use more than 5-6 psi for the dent to pop out. I do have a spot welding slide hammer tool, but this air pressure method has worked very well for me.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
