8750 would only get you to 1960 (Click on 'Serial Numbers' under 'Research & Info' in the column to your left and you can see for yourself.) The other kind of grill with the horizontal bars is listed on the CaseIH web site for serial numbers 501 to 23300. So yours should be above 23300 if it was born with that grill. Is there possibly a faded digit between the 37 and the 50 that would make it 37?50 ? That would be a 1968.
EDIT: I hadn't seen Hugh's post when I typed mine; I didn't know you didn't have a serial tag--but as far as I know, that trailing "J" (indicating Rockford clutch) is a sort of unique to serial numbers; you would not find that on a casting. So, I will echo the master, where DID you get that number? And where did you get 1959 as a year? This would help us figure out which is correct.
This post was edited by TheDurk at 15:07:52 12/06/08 2 times.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
