Posted by kippster on November 28, 2008 at 09:20:14 from (24.144.197.139):
In Reply to: mowing with an H posted by RustyR on November 28, 2008 at 09:01:50:
As long as you don't get into anything real heavy or thick, that H shouldn't have any trouble at all. She may have more than she can handle with a 6 footer in heavy stuff. Make dang sure you get an overrunning clutch for that pto shaft though. I was trying to be cheap and didn't buy one for my H and I ended up wiping out a guide wire for a utility pole and that cost me more than the overrun coupler. So just get one if you don't have one already, ok!
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
