Posted by D Slater on November 22, 2008 at 17:42:06 from (71.164.61.126):
In Reply to: SLipping TA on SMTA posted by GordoSD on November 22, 2008 at 16:26:24:
Yes thats enough, all the clutch has to do is release or slip to go in low range. In low range the clutch has nothing to do with the T/A slipping. In fact the T/A clutch parts could be removed from tractor and it would still pull in low speed if T/A unit is good. Your T/A unit needs repair. Could be a outside chance there"s heavy gear oil in transmission instead of hytran or similar oil, which could keep unit from working good in the cold climate. Other than that slim chance its tear down time. Also if you can shift in and out of transmission gears with no hang up problem thats a good sign that T/A clutch is releasing okay.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
