em, A starter repair shop (if theres any left near you) could likely do a conversion in the event you CAN NOT find any 12 volt with the right mount. I've never had any 6 volt starters go bad when I left them following conversion to 12 volts, however. It can be a bit tough on the mechanical starter drive due to the higher kick in torque, but it looks to me like have yours rebuit and converetd by a repair shop or (if thats possible) or else just get a good 6 volt which should last a longgggggggg time.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
