Posted by CNKS on October 25, 2008 at 17:47:54 from (216.144.104.128):
In Reply to: Re: M or Super M posted by Ed in TX on October 25, 2008 at 17:35:45:
If it is a M or Super M, or an H or Super H for that matter, the factory mounting for the battery was never next to the engine. On the H/Stage 1 Super H it was on the left side of the clutch housing, on the M/Stage 1 Super M it was mounted in front of the rear gas tank bracket behind the belt pulley drive. On the Stage 2 Super H and M it was under the seat. Sounds like yours has been modified.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
