Posted by Janicholson on October 23, 2008 at 13:50:45 from (66.173.50.11):
In Reply to: Attn: Jim N. posted by Dr. Bert on October 23, 2008 at 10:46:06:
It can replace the fluid and will probably be OK, but there are issues of operation that do not bode well for the swap. The Hydraulic fluid is (usually of less viscosity, and is often not EP rated, though some may be. 80-90 GL4 EP rated lube has a very stable thick viscosity that assists in slowing the gears when shifting. (especially from neutral into any gear). It also is formulated with extreme pressure additives which help keep the gears from actually touching under stress. The last reason is that the GL4 will be quieter in operation as it absorbs more sound. I hope this helps, Jim
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
