Posted by Ben Taylor on October 23, 2008 at 08:31:33 from (138.162.0.42):
In Reply to: locked up engine posted by gary conn on October 22, 2008 at 12:10:54:
I just got a '49 Super A unstuck that had not run for about 15 years. I ended up having to pull the head, spray PB Blaster directly on the pistons and let sit for several days. Most likely (at least in my case) the cylinder(s) that are stuck will not allow any fluid to drain, while the unstuck cylinders will allow fluid to pass. Once I had determined the most probable stuck cylinder, after pulling the oil pan, I used a piece of wood and floor jack to apply pressure directly to the crank at the connecting rod to the stuck piston. The next morning, I applied pressure with the jack to an unstuck piston that would put opposite pressure on the stuck piston, and, with another piece of wood, began tapping on the edge of the stuck piston. After several taps, the engine broke loose. Also, don't give up hope on the interior parts. After subsequently breaking down the engine completely, the only parts I am forced to replace are the rings and bearings...even the sleeves are in good shape. They don't make 'em like they used to!!
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
