Posted by Ry on October 22, 2008 at 18:04:05 from (66.128.167.0):
In Reply to: Gear Lube. posted by Dr. Bert on October 22, 2008 at 15:53:27:
GL-4 should work fine - just make shure it is EP "extreme pressure" and rated for hypoid gear use - not all gear lube is ok for hypoid gears - which just refers to the way most ring and pinion gears are cut. In other words if it is ok for rear axle use in your truck it will be ok for your C.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
