Posted by John - OH on October 22, 2008 at 04:22:41 from (74.5.133.66):
In Reply to: electrical short posted by 2146 north on October 21, 2008 at 16:45:47:
If switch is smoking, sounds like the contacts are burnt. If the switch comes apart, clean the contacts and see if the smoke disappears. Could also have problems that others described, but I would start with the switch.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
