Posted by John T on October 21, 2008 at 19:56:00 from (66.244.97.31):
In Reply to: electrical short posted by 2146 north on October 21, 2008 at 16:45:47:
A smoking starter switch could be caused by (among other things) a bad or stuck starter. Once you insure its not mechanically stuck/jammed to the flywheel gears thats causing the smoke, then youre still left with a bad switch or bad starter or cable or connection problems, but since the switch was replaced Ima thinkin more the starter itself (if its NOT a cable or connection problem).
If its a saddle type mount on the starter switch, the copper button/post that comes out the starter may be burned or corroded or carboned up or simply worn down too short n arcing causing problems. If its the stand alone up on the tractor 2 terminal push switch, while the switch may itself be bad, thats NOT the problem described before...
After you remove n clean n wire brush each n every battery n switch n starter n ground connection and if it still smokes, see if when you engage the switch the lights (turned on if it has any lights) dim way down badly and/or the battery voltage drops drastically????????? IF SO (assuming its NOT mechanically stuck/jammed) I SUSPECT THE STARTER IS BAD. HOWEVER if the lights dont dim much or the battery voltage dont drop much n the switch smokes, Ima thinkin more a switch problem, but a new switch should have cured that ????
The starter could have worn bushings allowing the armature to drag the field poles, that will cause excess current draw perhaps causing a switch to smoke and/or the starter to get real hot
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
