Posted by Janicholson on October 21, 2008 at 17:37:18 from (66.173.50.40):
In Reply to: electrical short posted by 2146 north on October 21, 2008 at 16:45:47:
The kind of tractor is pretty important, but here is some info: (be sure it is out of gear and brakes set) There may be a short, but less likely. The most likely is a combination of a stuck starter (jammed in the flywheel)and a failing starter switch. Loosen the starter bolts and shake the starter a bit, then re tighten, and try it. It may be OK, but it will need a starter switch soon. Bypass the starter switch with heavy gauge jumper cables (not booster cables) if the starter heavy switch is connected with cables to the starter on a stud and bolt. Touch the jumper to the starter terminal directly on the starter. (It will spark big, but should spin it) If this works it needs a new switch. If it has a switch mounted on the starter, and no external wire going in, then remove the switch, and use a jumper to the stud/lump sticking out. Again it is a bad switch if it works. Starters draw 400 to 500 amps on 6v and need great connections to keep from heating wires and switches. Be sure all cables have conductors in them as fat as a first grade pencil. (not the insulation, the copper!) Let us know what you find. JimN
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
