Posted by Pete in Holland, MI on October 21, 2008 at 15:50:37 from (24.247.182.9):
Guys -
Recently purchased 1939 F-20 has a missing problem. Every 1-5 seconds, the engine misses several firings in a row, then resumes with no hesitation/coughing or smoking. Not like a spark plug missing occasionally , but someone turning off & on the engine. Diagnosis has revealed these clues:
1) Each time the engine misses, a "gasp" can be heard from the carburator with the air filter hose removed.
2) Compression tests show dry results at 55-60, and wet results 55-60, across the board.
3) Spark plugs are clean & set right. Wires are almost new. Cleaned the fiber gear in the mag an cleaned the distributor brushes. The fiber gear does have about a 1/16" groove created by the brushes.
4) Carb has been adjusted lean & rich with little change.
5) More predominant at higher speeds. Less predominate at slow speed and spark retarded.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
