Posted by riverbend on October 15, 2008 at 18:52:11 from (208.160.33.200):
In Reply to: Farmall Super C value posted by Zach Bouchard on October 15, 2008 at 11:49:22:
If you have a use for the tractor and mower, $1500 might not be a bad price. I would not be too concerned about the crack if it is not leaking. The not running up hills is probably not a serious problem. Most Super Cs are able to climb hills...
Otherwise, buy the best tractor that you can afford.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
