Re: 350 carb failure?
Posted by old on October 05, 2008 at 17:05:19 from (4.245.4.204):
In Reply to: 350 carb failure? posted by wegman in mn on October 05, 2008 at 16:39:08:
Float could be sticking and or you may have some dirt in the float needle seat area. But the thing is you should ALWAYS turn off the gas when you park one for the day because its a common problem to have a small leak like that and that leak can end up costing you an engine because when they leak like that gas can/will get into the oil and then if you run it that can mean a rod or main bearing going out. I would be sure to check the oil and make sure it not over full and does not smell like gas. If its over full or smells of gas change it before you run it or it could cost you big $$ to fix
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
