Posted by ScottyHOMEy on October 02, 2008 at 11:32:22 from (71.241.192.129):
In Reply to: Re: Farmall A or B? posted by ScottyHOMEy on October 02, 2008 at 11:01:23:
The narrow fronts of the Bs were entirely different castings from the wide front As.
Two ways to make that kind of "hybrid" I mentioned. 1) Shorten up the left side of a B/BN with the shorter differential shaft from an A and eliminate the need for the longer housing or 2) start with an A and replace the whole front casting with that from a B/BN.
If you have such a beast, the model on the Ser# plate will tell you which way it was done.
I've heard it said that there was a factory option for a wide front on a B (never seen one, just been told) but I've never heard of the factory putting a narrow front on an A.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
