Posted by Mike Farmer on October 02, 2008 at 11:10:48 from (86.31.84.127):
In Reply to: Farmall A or B? posted by chickenfarmer on October 02, 2008 at 10:46:47:
Hi. The layout of these two tractors is different. Everything on The A is offset to the left i.e. the right hand axles are longer than those on the left. Everything on the B is central i.e. the rear axles are both the same length MTF
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
