I don"t have one, but I"ve been looking at them. They have a swing mechanism, more like an excavator than traditional backhoes, with built in cylinders that push a movable gear rack past a fixed pinion shaft. As I understand it, the problem is that the pinion shaft is held fixed by a plate that matches the vertical splines, and those splines wear over time. As a result considerable looseness develops between the plate and the shaft. The parts are not available any more. There are links on this site to other"s experiences with 3414"s.
I"m looking at a 3444 next week. Do you know how much the 3414 weighs? I"m trying to line up transport if I do buy one.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
