Posted by J.J. from Afton on September 25, 2008 at 19:42:18 from (139.225.250.243):
In Reply to: Curiousiou posted by hayfarmer on September 25, 2008 at 17:46:53:
Ya it would be pretty neat to own one of those setups.
Stieger used the concept in the mid-late 70s. They built a twin engine experimental and a triple engine one that had over 1000 horsepower.
Cat also ended up using the concept. They joined two D9s making a DD9 I think they called it. They used the same thing with some of their belly scrapers. They even ended up building a Triple scraper.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
