Posted by spiffy1 on September 25, 2008 at 18:18:09 from (70.41.136.71):
In Reply to: Curiousiou posted by Janicholson on September 25, 2008 at 17:46:53:
http://www.mccormick-deering.com/storyGem01.html
Check out the picture in the bottom right of the link. Seen a different one too, neither JD or IH, linked back to back and IIRC, articulated rather than the front end left on either; a quick web search yeilded the above, but not recalling the make, no luck with the latter.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
