Posted by Farmall JD on September 13, 2008 at 07:48:20 from (24.137.36.116):
In Reply to: Farmall TA posted by Jason from MI on September 13, 2008 at 05:36:14:
Jason, I found the article. The T/A is only ment for sort periods. Its just ment to get you through the rough spot. It has its own flywheel clutch pressure plate and dry throw-out bearing. With the leaver ahead the throw-out bearing is not spinning and the engaged clutch causes the whole T.A. unit to spin as a soild unit with no gear reduction. when you pull the leaver back it release the clutch and the T.A. starts doing its job. There is onething at the back of the T.A. that has to work to make it run in T.A. mode. They call it a over running or "sprag" clutch. It is used to hold the housing with the gears in it still so the gear reduction can happen if it is not working you won't get the T.A. action. If you engaugethe T.A. and you hear a little whine and the tractors stops moving then you have a bad sprag clutch.
I got this info out of Red Power Magazine. Vol23, No3 It has a great atricle on the T.A.'s in it and the next issue says its going to talk about adjusting, rebuilding and where to get parts for them..
Good luck and I hope I have helped :)
This post was edited by Farmall JD at 08:18:17 09/13/08.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
