Re: Re: Re: C repair/restoration
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by MoosieDog on March 22, 2000 at 17:25:23 from (12.78.117.94):
In Reply to: Re: Re: C repair/restoration posted by mk on March 22, 2000 at 15:56:01:
A needle scaler is an air tool, much like a mini-jack hammer. It works with a similar action; except, instead of a single chisel bit, there are nine, one-eighth inch diameter steel rods that protrude out of the barrel. These extend out about ten inches and are independant of each other. There are several models, some with a pistol grip, some straight. I use an Ingersol straight barrel. The entire unit is about 22 or so inches long. Prices range from about $100 to over $ 300, depending on the control options and quality. Held at an angle to the workpiece, the vibrating needles "peal" off heavy rust or multilayers of paint and debris. Held at 90 degrees, it pulverizes paint and does not have the tendency to score if one develops a touch. It is very efficient and quick with no dust floating around compared to sanding or blasting, no mess compared to paint remover and no little steel wires flying around compared to high-speed wire brushes. Even more impressive is it's ability to get into impossible areas to clean. The needles will slide into small recesses that nothing else would get to. I use it also to clean metal stock prior to welding and to remove slag and drip after welding. The needles last nearly forever, but are replaceable and can be reground flat if they round out. I run off a small 5 hp shop compressor at about 125 psi. If you work on old farm machinery, you need one.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
