Posted by BlakeinTN on September 08, 2008 at 16:47:05 from (66.38.116.245):
I took the tractor out, and went about 40 yards before it cut off. It died just like the key had been turned off, but the amp light came on, like it does with the key on before I start the tractor. I did some checking, found no spark coming from the coil. Coil is new, and measures 3.3-3.7 ohm across it with all three wires removed.
Today, I put on a freshly charged battery, new condenser, points, distributor cap, and rotor. I hooked up the battery and when I tried to start the tractor, the starter just clicked, then when I released the start button everything shut off, just like I had turned the key off. I disconnected the battery and found one of the two small wires that go into one connector on the solenoid broken. I fixed the wire, then reconnected the battery and tried to start the tractor again. The starter clicked, then everything shut off when I released the start button. I noticed small wisps of smoke coming out the the starter this time, where the little bar comes out of the starter body and connects to the solenoid.
I'm assuming the starter is bad now, but I will have it tested tomorrow. My question is, could there be a common cause for both the tractor dying, and the starter going out? Where should I start looking?
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
