Posted by GordoSD on September 04, 2008 at 20:10:56 from (66.115.200.140):
In Reply to: Farmall spark plug problem posted by John in Pennsylvania on September 04, 2008 at 18:48:38:
A "piece of carbon" indicates a fuel mixture problem. Carbon is unburnt fuel. Oily, greasy wet plugs would be a valve/ring problem. Try leaning the fuel/air mixture. Also go up one more range hotter plu til you get burnt carbon.(orange/white)
Also try cleaning the plugs, then start the tractor and run at high idle. Shut off with ignition while at high idle. Check plugs.
Then clean the plugs and run at low idle. Shut off with ig switch. Will tell you where the rich mixture is.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
