Perhaps the ammeter isnt wired correct?? (may have got rewired if battery polarity was reversed) Theres usually just ONE wire on its SUPPLY terminal that connects to the battery/starter for the main hot battery feed/connection and over on its other LOAD terminal it wires to the BAT terminal on the Voltage Regulator PLUS can feed hot battery voltage to lights and ignitiion via a wire from the ammeters LOAD terminal to the switches BAT input terminals. If the batetry and loads are on the same side of the ammeter it doesnt read correct...
Then if its wired correct n shes not running if you turn on lights it ought to swing over to - discharge. if it swings to + charge its wired bass ackwards n needs its leads swapped. When the battery polarity was reversed the ammeter leads needed swapped to make it read correct, maybe it never got rewired correctly after that????
To see if shes charging place a voltmeter on the battery and it should read around 6.3 volts setting there but when running at fast RPM it should raise to the 6.5 to 7 volt or so range. If it does that its indeed charging even if the ammeter isnt wired correct.....
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
