You will need to pull the head too. You will need a sleeve puller to pull the sleeves. You probably will need a ridge reamer so the rings will clear the top of the sleeves. You probably need to check that block bore on the sleeve that broke. Probably wasn't tight enough in the block. Just remove the rod nuts and cap and you should be able to drive out the rod and piston. Use a piece of 2X2 oak and a big hammer. Hal
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
