Posted by Owen Aaland on August 21, 2008 at 18:54:06 from (65.161.86.52):
In Reply to: 1466 transmisson posted by cobra1379 on August 21, 2008 at 14:29:41:
Are you sure you have two different speeds when selecting first or second gear? I think you will find that there is a problem with the 1-2 shift fork or linkage under the shift cover. Is the roller missing from the arm that moves the shift fork? A missing roller may allow the 1-2 gear to remain partly engaged when you shift to 3 or 4.
The steering and brake problem most likely is in the MCV. The pump may be weak but it must work some because you have steering and brakes before the dump valve is activated.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
