Posted by teddy52food on August 19, 2008 at 06:23:41 from (209.237.111.169):
In Reply to: Compression posted by d282 on August 19, 2008 at 05:50:13:
If the tappets were too tight it may lose compression but I don't think 10 minuetes of running would warm it up enough to hold them open. The cold oil on the first test would seal better than the warm oil on the second. Does it smoke blue? Like Jim said, was the throttle open for both tests?
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
