Posted by Janicholson on August 19, 2008 at 06:13:34 from (199.17.6.122):
In Reply to: Compression posted by d282 on August 19, 2008 at 05:50:13:
I would not be sure it had the throttle in the same place on the second try. If the throttle is closed, it will be sucking a partial vacuum and not read accurately on the gauge. Run the tractor, it will be fine (opinion) JimN
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
