Posted by Nebraska kirk on August 05, 2008 at 16:16:22 from (98.16.171.154):
In Reply to: Belt Pulley Oil posted by CHIEFEAVES on August 05, 2008 at 06:11:44:
You don"t have to remove the entire belt pulley assembly to get the diesel out, just remove the four bolts behind the hub that the pulley bolts to and pull the shaft out. You can then examine the gears and bearings and clean out all the gunk.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
