Re: IH 709 tractor hydraulics?
Posted by Allan In NE on August 01, 2008 at 05:55:54 from (148.78.243.26):
In Reply to: IH 709 tractor hydraulics? posted by SteelGiant 30 on July 31, 2008 at 19:26:47:
That isn't how it works.
The plow should try to dig itself to China and the tractor should have to hold it back out of the ground.
"Forcing" a plow in the ground is a good way to bust something.
So, like the other guys say, if it won't go in the ground, the problem is either with the plow, with the soil or the way the plow is set up.
Allan
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
