Posted by JimB2 on July 30, 2008 at 17:04:53 from (99.241.179.24):
In Reply to: 484 question posted by russ hamm on July 30, 2008 at 08:28:21:
Hi Russ at 2044 Hrs it is hardly broken in. My brother still has 454 (older model of 484) that we bought in 1972 with over 15,000 Hrs, still starts and runs great. We put on 16.9 x 28 rear tires, fluid and weights and had the pump turned up so that it was putting out over 50HP but with no surprise, the second year we had it had to put a HD clutch from 674 in it. We pulled a 10ft IH disk, 3x14 plow, baler with thrower and 1 row IH#16 forage harvester. Later my brother also purchased the newer model 495 but the 454 will out pull it any day.
The weak point of these tractors are the hydraulic brakes, the seals in the wheel cylinders leak after many years and air gets in the braking system. The other problem is if someone leaves the parking brake on and drives the tractor. The chewed up parking brake band bits get into the hydraulic system and cause MCV valve problems.
Use 15W-40 Diesel engine oil and add some conditioner or couple of table spoons of engine oil to the Diesel tank every time you fill up. This will help lube the front lip seal on the fuel injection pump as the new low sulphur fuel does not have the required lubricity for the older injection pumps.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
