There is a large oil seal in there, it seals against the hub of the brake drum. You will have to pry, hammer, chisel it out :-)then replace with a new one, any good automotive parts store can cross the number on the old seal and get you a new one. The old seal is about 3/4 inch thick while a new one will be about half that thickness, that is not an issue, tap the seal in until it is flush with the outside of it"s recess. The cork washer keeps oil from leaking out between the splines.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
