Posted by CHIEFEAVES on July 14, 2008 at 14:03:48 from (64.12.116.73):
I am re-assembling the 1939 M Farmall. Have had the bolster laying horizontial for several months. Now that I have it mounted, I took the top plate off the steering gear portion to check for lubricant. The operator manual indicates it should have 1 pt of SAE-90, however what is there appears to be regular alimite grease. Is it possible that the grease from the alimite lower down on the front of the bolster has moved up due to it having been layed down? What action should I take? Thanks Harley
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
