Re: IH544 cam bearing installation
Posted by John G. Hasler on July 12, 2008 at 07:23:10 from (69.179.121.5):
In Reply to: Re: IH544 cam bearing installation posted by El Toro on July 12, 2008 at 04:45:53:
> Your engine oil pressure is determined by close
> tolerances on the cam bearings.
Only if they are so loose that the pressure cannot reach the 38 psi limit set by the oil pressure regulator.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
