Take a steel plate and put it insde the block behind the journal in the block for the cam bearing and place another on the outside of the block with the bearing lined up in place and with a bolt you can pullit in without damage to either the bearing or the cam and just stack washers up if the threads aren't long enough to pullit fully into place. much better than tring to drive it and can be controlled for tension then just slip the cam in.The plates will obviously need holes drilled in them for the bolt probably about a 3/4 or 5/8 would be big enough and if your worried about alignmentuse pipe sections over the bolt to fill the void in the bore just be sure they are shorter than the journal thickness. Hope this helps. I've pulled many a seals and bearings into place this way.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
