Posted by Rad Redrunner on July 03, 2008 at 06:47:48 from (24.233.197.61):
In Reply to: Hey, Rad Redrunner posted by ScottyHOMEy on July 03, 2008 at 05:12:04:
Nope, Scotty, the serial number was clean and easy to read, 386**D, and the "D" is definitely a "D". There are prefix letters stamped together in a straight line (machine stamped?) in the top left corner of the planed area- "FCM" or "FMC", one or the other, can't recall exactly- could this be a replacement-ordered block?. I haven't been out yet to check on how the pump is mounted, but it's in the normal position and all, so is it possible that holes were drilled and tapped on an older block? (Was there room for this on the original A block?) A lot of trouble, true, but who knows what people did on these things in five decades.
As for the governor, yeah, that's what I'd planned to do, and I think the shorter spring is toward the front, so meeting the adjustments halfway would be next, I guess. I think I'll crank it up and try it out before I do anything else, just to see how it runs and what the range is. Before, the throttle lever would go back enough to kill the motor (restricted fuel flow?) and seemed to "top out" before the engine revved quite as high as it seemed it should. (Yes, I know they don't rev really high.) It's strange that there would be as much difference as you mentioned in the effective range of the throttle action on individual tractors, especially when the mechanics are so basic and supposedly the same; I don't doubt you at all, it's just weird.
So it's back to the tinkering again. At least the belts are on and everything is spinning, so I can crank it and check things out better. I really appreciate you sticking with me on this, Scotty, it sure makes it easier to dive into rather than going into a system completely blind. I've never dealt with a governor on an engine before, but I guess it's aptly named; it's placed between the working man and the power in order to control that power and it doesn't always act like it's supposed to or do what the working man wants it to do. I hope I don't have to impeach this one.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
