Posted by steelfronts on June 30, 2008 at 19:05:08 from (24.236.150.155):
In Reply to: 15-30 mag timing posted by Albertagary on June 28, 2008 at 21:05:53:
The easiest way is to remove the number one spark plug put your finger in the hole like a cork and turn the engine slowly till compression leaks past then you know you are coning up on one compression. then take a long thin screwdriver put itt in the hole and move the engine over carefully till th screwdriver stops coning up. thats should be TDC take cap off mag look where rotor is pointed should be at no 1 terminal.To play it safe remove all the spark plugs first. If the mag is way off while its on TDC at this point remove valve cover and acertain that both valves are closed. Then remove the two 1/4 inch fine thread bolts holding the mag drive together and rotate the mag untill the points are just starting to open with the rotor approaching the no one terminal. also the mag should be fully retarded during this adjustment. replace the bolts they will only line up in the correct holes usually either straight horizontal or vertical
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
