Posted by CNKS on June 26, 2008 at 17:37:33 from (216.144.104.128):
In Reply to: SC hydraulic pump posted by Idaho Ron on June 26, 2008 at 16:08:23:
The parts manual has pump numbers and the pump itself has corresponding numbers stamped on it -- they are in the parts manual or www.caseih.com. I believe yours has an o-ring, which is generic and available at NAPA, or better, a bearing/seal business. CaseIH likely has it in stock. If the shaft itself has a deep enough groove in it, you will need a speedi- or redi-sleeve. This requires enlarging the hole the pump shaft goes through. Best to have that done at a machine shop, which can also supply the seal and sleeve. It is a simple repair.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
