> I just rebuilt a 544 engine last week. I had my > machine shop bore the block and install new cam > bushings.So I can't say for sure but i think the > rockers get there oil thru the cam bushings. it > is possible the bushings spun and the holes are > blocked.
Good idea. I hadn't thought of the bearing being spun. I'll see if the governor is getting oiled as according to the shop manual it gets oil from there as well.
On further thought, it seems like that should stop the cam followers from getting oil, though.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
