Hi Rotax, for hydraulics use IH Hytran hydraulic fluid or equivalent. Although my B414 Ops Manual says that non-detergent 20W tractor oil can be used for hydraulics. Hytran is better because it will absorb some moisture. Transmission oil is below 32F, gear 80W and above 32F gear 90W.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
